Emmylou083
Aug 02, 2021Guide
Orbi parental controls
I get an error when trying to toggle off ore tal controls (unable to toggle state SPC-DISABLE-FAIL) and also when I attempt to add a device to a profile. I want SPC on but was trying to troubleshoo...
Emmylou083
Aug 03, 2021Guide
Firmware version: V2.7.3.22
Does a factory reset unwind all of the firmware updates? I had to do several manual updates to get to recent firmware versions, so just curious. I have not performed a factory reset since all of those updates several months ago.
Aug 03, 2021Guru - Experienced User
No. Just clears out configurations and any lingering old FW code.
- Emmylou083Aug 03, 2021Guide
ok perfect, thanks! I'll have to find some downtime for everyone (any myself with WFH) to give that a try.
- FURRYe38Aug 03, 2021Guru - Experienced User
Let us know how it goes...
- Emmylou083Oct 04, 2021GuideSo I did this and it worked fine. Parental controls have worked again for about a month and have now stopped working. I haven’t done any firmware updates and there are no news one currently either. Why does this keep happening?
