obeythelaw2020
Jun 07, 2024Aspirant
Orbi RBR 750 can't get parental control tile
Hello. I purchased my Orbi RBR 750 more than a year ago. I had some issues with the initial firmware and stopped using it and started using an Eero Pro 6. After seeing the new firmware update to ...
obeythelaw2020
Jun 10, 2024Aspirant
Thanks for the suggestions. I've tried them all and still no parental controls tile. I did speak to Netgear support yesterday and they have escalated to a "Level 2" technical support team.
Jun 10, 2024Guru - Experienced User
Hopefully they can get it fixed for you.
