fdarrenlacy
Feb 24, 2025Initiate
ORBI RBR750 - Android App Crashes in Parental Control Area
RBR750 with 3 Satellites FW Ver 7.2.6.31 Orbi App Ver 2.43.0.4421 Android Ver 14 Starting 2 days ago, the android orbi app crashes when using the parental control module. If history is enabl...
Mar 04, 2025Guru - Experienced User
fdarrenlacy mib123 Kevin0 Marauder44
Has your Orbi 750 series systems been updated to newest version of FW yet?
- Marauder44Mar 04, 2025Tutor
My current FW version is 7.2.6.31. When I check for an update via the Orbi app it says the FW is up to date.
- FURRYe38Mar 04, 2025Guru - Experienced User
New FW may or may not be seen by the Orbi app or pushed by NG, so manual update maybe needed.
- Marauder44Mar 13, 2025Tutor
Doing a manual update to the system and two satellites seems like a lot to ask from a standard/non-technical user. It's time-consuming, not straightforward, and could take down the network if not done properly. It's just a terrible user experience for something that costs so much.
- Kevin0Mar 04, 2025AspirantRBR760 running latest FW v6.3.8.5
Crashes when in parental controls.
I think it is linked to user being timed out on wifi access.
