mib123
Nov 05, 2022Tutor
Orbi RBR750 doesn't have Smart Parental Control feature
I have Orbi RBR750 Firmware Version V4.6.9.11_2.3.5 How do I enable the Smart Parental Control feature? It is not on my Android app (v 2.20.2.2506) and nothing in the GUI admin access portal eith...
michaelkenward
Nov 06, 2022Guru - Experienced User
How do I enable the Smart Parental Control feature? It is not on my Android app (v 2.20.2.2506) and nothing in the GUI admin access portal either.
Is see no hint that the Orbi RBR750 supports parental controls.
Which products support NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
