mib123
Nov 05, 2022Tutor
Orbi RBR750 doesn't have Smart Parental Control feature
I have Orbi RBR750 Firmware Version V4.6.9.11_2.3.5 How do I enable the Smart Parental Control feature? It is not on my Android app (v 2.20.2.2506) and nothing in the GUI admin access portal eith...
michaelkenward
Nov 06, 2022Guru - Experienced User
How do I enable the Smart Parental Control feature? It is not on my Android app (v 2.20.2.2506) and nothing in the GUI admin access portal either.
Is see no hint that the Orbi RBR750 supports parental controls.
Which products support NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
mib123
Nov 06, 2022Tutor
Thank you, but it does. RBR750 is listed in the Netgear Smart Parental Control list
- CrimpOnNov 06, 2022Guru - Experienced User
The RBR750 Product Data Sheet prominently mentions Smart Parental Control on page 1.
https://www.netgear.com/images/datasheet/orbi/RBK752.pdf
and on page 4:
I find it (almost) amusing that the word "Parental" does not appear in the RBR750 user manual.
On my Orbi app, Parental Controls is the bottom right panel. Maybe it has scrolled down out of sight?
p.s. The current fiasco with the Orbi 'app' may in some way be affecting what shows in the app.
- michaelkenwardNov 06, 2022Guru - Experienced User
I looked at the KnowledgeBase articles and found no mention. Maybe it was an old page that needs fixing.
Sadly, Netgear's manuals rarely get updated to reflect changes made in new firmware. Many still refer to the old and long dead parental controls.
