mib123
Nov 05, 2022Tutor
Orbi RBR750 doesn't have Smart Parental Control feature
I have Orbi RBR750 Firmware Version V4.6.9.11_2.3.5 How do I enable the Smart Parental Control feature? It is not on my Android app (v 2.20.2.2506) and nothing in the GUI admin access portal eith...
HIM
Jan 11, 2023Aspirant
Did you receive an answer for your quesiton? I have the same one. It seems as though my orbi router is supposed to have the parental controls, but I don't see the parental control tile...anywhere. I have the RBK753
- michaelkenwardJan 11, 2023Guru - Experienced User
Whose question is that? Which question?
Did you read the message from KevinLiT?
The one just before your message.
You have joined in on a conversation from last November. It has quite a few messages and things to try. If they don't work for you, then you might do better to start with a new message, including the relevant details as discussed in earlier messages.
