mib123
Nov 05, 2022Tutor
Orbi RBR750 doesn't have Smart Parental Control feature
I have Orbi RBR750 Firmware Version V4.6.9.11_2.3.5 How do I enable the Smart Parental Control feature? It is not on my Android app (v 2.20.2.2506) and nothing in the GUI admin access portal eith...
KevinLiT
Nov 25, 2022NETGEAR Moderator
Hello mib123,
Thank you for your post!
I understand that you would like to enable SPC from your Android device.
To enable SPC from your Android device please do the following in your Orbi app:
HAMBURGER MENU > SETTINGS > PARENTAL CONTROLS > toggle ENABLE SMART PARENTAL CONTROLS
(PBA: A factory reset may be required )
Best,
Kevin
Community Team
aeolus492
Feb 07, 2023Initiate
I also have an RBR750 without parental controls. However, I have iOS and cannot see the tile within the app. The web interface isn't showing parental controls either. Just installed the latest app on my phone, the latest firmware on the Orbi RBR750, and all of this is from a factory reset last week. Any help would be great.
- iyangFeb 08, 2023NETGEAR Expert
Hi aeolus492 ,
Can you share the screenshot for App ?
Can I know what's country are you located at?
Because smart parent control does not support in some country.
Thanks.
- aeolus492Feb 15, 2023Initiate
Oddly, a few days ago when logging into the orbi app I was presented with parental control options. I set them up, and the button now appear in the menu. Again, this was nearly a week after a factory reset and firmware update. There appears to be a delay in the processing of the parental controls after a factory reset. Additionally, before the options appeared I did some digging into the code on the web interface and could see that a CSS class was hiding the parentals controls button. So IDK what is going on with their firmware / gui but it's strange.
