Ace321
Jul 14, 2021Apprentice
Orbi RBR750 firmware 4.6.3.7_2.0.49
Nertgear released new firmware and release notes says.. Supports Smart Parental Controls (SPC) Any idea what this is and how to use it?
Jul 14, 2021Guru - Experienced User
- Ace321Jul 14, 2021ApprenticeThank but I do not see SPC tile as per instructions in Orbi app.
- Ace321Jul 14, 2021ApprenticeNever mind it finally showed up as a pop up. Thanks
- FURRYe38Jul 14, 2021Guru - Experienced User
Is the Orbi app up to date?
Try a different mobile device?
Has a power OFF of the RBR for 30 seconds then back ON been done after the FW update?
Might try a factory reset as last resort...
Make contact with Christian_R over in the SPC forum if you can't seem to get it enabled...
Ace321 wrote:
Thank but I do not see SPC tile as per instructions in Orbi app.- FURRYe38Jul 14, 2021Guru - Experienced User
Also try un-installing Orbi app then re-install it...
