Ace321
Jul 14, 2021Apprentice
Orbi RBR750 firmware 4.6.3.7_2.0.49
Nertgear released new firmware and release notes says.. Supports Smart Parental Controls (SPC) Any idea what this is and how to use it?
Aug 14, 2021Guru - Experienced User
You not seeing anything in the Orbi app?
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
LiquidP wrote:
<<I previously posted somewhere else and is redirected to post here>>
I have a RBK753 purchased from COSTOC.
Now it runs on V4.6.3.7_2.0.49 on all 3 units (One RBR750, two RBS750). I could not find SPC in either the Orbi mobile app, or the web UI.
I did a few things
- factory reset on the entire kit last night,
- uninstall/reinstall Orbi app on my android phone,
- clean up the storage/cache on my android phone,
- install Orbi app on my wife's iPhone.
It does not offer me with SPC.
Anyone know what else trick I should try, or help me debug this issue. Your input is appreciated.
Thanks!
LiquidP
Aug 14, 2021Tutor
That is correct. It does not offer SPC tile on the orbi app.
- FURRYe38Aug 14, 2021Guru - Experienced User
Will have to see what NGs repsonce is for this...
- LiquidPAug 14, 2021TutorThe Orbi app finally offers a "Add Ons". And in that UI, there is only one "security" and that is also grey off.
- Christian_RAug 16, 2021NETGEAR Employee Retired
Hi LiquidP,
Can you confirm your region and router serial number for me to check further. Please send me a private message with the requested info.
Thanks,
Christian
