breakc0de
Dec 22, 2022Tutor
ORBI RBR750 Smart Parental Controls - Activation fails after FW upgrade
I purchased a year of SPC from netgear when I bought my ORBI RBR750 with 2 satellites. They have been working great until after a FW upgrade. I logged in to the Orbi app and noticed the app prompting...
- Apr 17, 2023
Yes, they finally fixed my issue. They did something on the cloud services side, then told me to reset my router and reinstall the ORBI app on my phone and it worked. I wasn't given any other details on the fix they made. But I did NOT have to update my FW on the ORBI, so it was something to do with the communication with the web service that allows the parental controls to happen.
breakc0de
Dec 22, 2022Tutor
I purchased a year of SPC from netgear when I bought my ORBI RBR750 with 2 satellites. They have been working great until after a FW upgrade. I logged in to the Orbi app and noticed the app prompting me to re-activate the SPC. It tries to activate and then gives and error "Activation failed". I tried many things including hard reset (factory reset) on all devices, delete the ORBI app, reinstall and did a new setup of the ORBI routers. I did this 2 times. I tried removing all the profiles from the parental controls area, then tried to reactivate and nothing has worked. I am now stuck with non functioning Smart Parental Controls feature. Please HELP!!
FW: V4.6.14.3_2.3.12
