breakc0de
Dec 22, 2022Tutor
ORBI RBR750 Smart Parental Controls - Activation fails after FW upgrade
I purchased a year of SPC from netgear when I bought my ORBI RBR750 with 2 satellites. They have been working great until after a FW upgrade. I logged in to the Orbi app and noticed the app prompting...
- Apr 17, 2023
Yes, they finally fixed my issue. They did something on the cloud services side, then told me to reset my router and reinstall the ORBI app on my phone and it worked. I wasn't given any other details on the fix they made. But I did NOT have to update my FW on the ORBI, so it was something to do with the communication with the web service that allows the parental controls to happen.
Dec 22, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
breakc0de
Dec 22, 2022Tutor
Hi thank you for your reply. Yes I have tried factory resetting now 3 times. I just tried what you suggested and did full unplug of modem and router. Then factory reset the router and performed the ORBIT setup wizard using a wired computer and the web browser. I went to then go activate the SPC and it still gives me "activation failed".
I have tried everything you suggested in your reply, is there any other avenue to fix this issue? Is this a software bug?
I also filed a bug through instabugs using the ORBI app. Please help!
- CrimpOnDec 22, 2022Guru - Experienced User
Perhaps this would be a good place to start:
https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service
- breakc0deDec 22, 2022Tutor
I went through several rounds of troubleshooting with Netgear chat representative.
- I tried updating the firmware manually to the latest version (even though it had already been installed). SPC activation still fails
- Downloaded the ORBI app another device to try to active SPC - SPC activation still fails
- Factory reset router/satellites used the Web interface to setup ORBIs again - SPC activation still fails
- Factory rest router/satellites uninstalled the ORBI app - reinstalled ORBI app, setup ORBIs AGAIN - SPC activation still fails.
The end of the chat is the representative said he would escalate the case.
- breakc0deFeb 15, 2023Tutor
My issue still exists. I have not been able to use my smart parental controls for about 3 months now. It is supposedly in level 2 support now, I have sent support several instabugs and debug logs from my router and still no solution. This is getting ridiculous. I paid a lot of money for this Orbi, AND they are charging me to use a broken SPC!!!
