breakc0de
Dec 22, 2022Tutor
ORBI RBR750 Smart Parental Controls - Activation fails after FW upgrade
I purchased a year of SPC from netgear when I bought my ORBI RBR750 with 2 satellites. They have been working great until after a FW upgrade. I logged in to the Orbi app and noticed the app prompting...
- Apr 17, 2023
Yes, they finally fixed my issue. They did something on the cloud services side, then told me to reset my router and reinstall the ORBI app on my phone and it worked. I wasn't given any other details on the fix they made. But I did NOT have to update my FW on the ORBI, so it was something to do with the communication with the web service that allows the parental controls to happen.
Cayenne08
Apr 17, 2023Guide
Has anyone gotten any updates on this. Big let down been paying for a couple years feel like this happens every year.
breakc0de
Apr 17, 2023Tutor
- FURRYe38Apr 18, 2023Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
