rosendo
Sep 13, 2023Follower
orbi850 access control option
I have the orbi 850 and have not been into the system in a while as far as updating or anything. earlier today under the access control tab I was able to block and unblock no issues. then I updated t...
Sep 13, 2023Guru - Experienced User
IF you have Smart Parental Controls enabled on the Orbi app, then I belive this will take over the WEB Ui function and you'll need to use the Orbi app.
