zolo
May 16, 2022Tutor
parental control for Nighthawk x10 AD7200
I purchased a Nighthawk X10 not too long ago, partially because it has parental controls. I tried to set them up today and after 2 hours realized that it is no longer supported. Does anyone have idea...
zolo
May 16, 2022Tutor
My understanding is that Netgear has removed the following parental control applications
1) removed parental controls from the Nighthawk x10 Router
2) removed the Circle on Netgear app from app store
3) removed accessibitily from using OpenDNS
Is this what others have detemined? They have just gutted ALL possibilities of using parental controls?
Netgear advertises that its newer routers have new parental controls built in, but I have heard from multiple people that these are also going to be removed soon. I think Netgear just sucks - anyone want to buy a new x10 router for real cheap - if not its going in the trash can
michaelkenward
May 16, 2022Guru - Experienced User
No.
You may be looking in the wrong place, If anything there are too many places go look for parental controls. Maybe you just got lost. Easily done.
PS There are also ways to get the free stuff to work.
- zoloMay 16, 2022Tutor
the website you sent me to states to to the following:
1. Launch the Orbi app or Nighthawk app
2. Tap Parental Controls tile
I did this on the Nighthawk app and there is NO Parental Controls tile. Does not exist. Try it yourself, there is no tile or any mention of parental control on the Nighthawk app. So your solution is meaningless
- michaelkenwardMay 17, 2022Guru - Experienced User
- zoloMay 17, 2022Tutor
what version of nighthawk app is that - I do not have that tile anymore after updating to newest version?
The latest for Android.
V2.17.0.2193 Nighthawk
V.2.16.0.2128 Orbi.
Of course, it will not show for routers that do not support parental controls or if they do not have the right firmware.
