zolo
May 16, 2022Tutor
parental control for Nighthawk x10 AD7200
I purchased a Nighthawk X10 not too long ago, partially because it has parental controls. I tried to set them up today and after 2 hours realized that it is no longer supported. Does anyone have idea...
zolo
May 16, 2022Tutor
its certainly possible the number is wrong, bc almost everything on the Netgear site I have read seems to be wrong, but here it is:
https://www.netgear.com/support/product/R9000.aspx
it clearly states x10 ad7200
zolo
May 16, 2022Tutor
to be 100% clear, the box I bought it in states: Model x10 ad7200
- michaelkenwardMay 17, 2022Guru - Experienced User
That is true.The box also says "Router", but that tells us nothing fo tell it part form any other router that might be in the box.
As explained, it is not a Netgear model number. It is a wifi speed indicator.There may be dozens of different devices with that speed technology., You will even find those labels on different brands.
The label on the thing clear says what the Model Number is:
