AE8U's avatar
AE8U
Parental Control question
We want to time limit internet access by device (either by Mac address or ip). But we need to do this without needing to install an app on the device. The kids have school owned Chromebooks that precl...
  • FURRYe38's avatar
    Feb 14, 2022
    Depends if your NG product supports Access Controls with a schedule.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
