dd-walker
Feb 06, 2022Tutor
Parental Control stopped working
I have Parent Control subscription for about a month. It's been working fine. But today it stopped working. It doesn't show usage History and doesn't limit the usage. The firmware version is 2.7....
- Nov 07, 2022
(For some reason all the other related topics have been marked as closed)
Netgear Support finally resolved the issue I had with SPC not working following the force migration in January 2022. Basically, it would work for a few hours and then stop applying rules, logging history, etc. It was resolved end of October.
The problem was caused by Circle settings not allowing Netgear SPC to work. Level 3 support recreated by setup in their lab and built a script that deleted all trace of Circle.
After running this script into the router, I did factory reset and reinstalled the app. The profiles weren’t lost and SPC has been working for 2 weeks non stop now.
So if you are a previous Circle user on Orbi and could never make SPC work, they have a solution. Just need to point them to Level 3 script they have built. (PM me for my case number)
Thank you to Bernard for Level 2 who finally got this resolved.
Feb 07, 2022Guru - Experienced User
What device(s) have you installed Orbi app and Circle on? Try a different device to compare results?
The firmware version is 2.7.3.22.
What shall I do? Thanks.
dd-walker
Feb 07, 2022Tutor
I'm using Comcast (business) Internet. The modem model is Cisco DPC3008.
I installed the Orbi app on my android phone.
I haven't tried factory reset.
- dd-walkerFeb 07, 2022Tutor
I called tech support, and was told to do a reset. Afterwards, parental control works again.
- plemansFeb 08, 2022Guru - Experienced User
Happy it was the easy of a fix.
If you mark your solution as solved, it might help the next person with that problem.
- FURRYe38Feb 08, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- Chuckg1Feb 11, 2022Star
dd-walker, it will fail again.
Join the club of the factory resetters that make it work for 2-3 days and then it will stop working again. They have no clue what is the root cause. I have a case opened with Netgear on the same version and hardware and in the mean time, paying for a subscription on a product that shows no history, no usage, no filters. I didnt the whole factory reset, reinstall app, redo configs many many times and it always end up failing after a few days. This product is not working. Too bad they forced us to go away from Circle.
