WendyJune73
Mar 31, 2023Initiate
Parental Controls gone RBR750
This morning my parental controls are gone. Rebooted, nothing. Tried to enable parental controls, cloud error. Uninstalled app, reinstalled, now my subscriptions do not show up and the parental co...
- Mar 31, 2023
Was told that SPC should be fixed now.
Please let us know if this has been fixed for you.
WendyJune73 wrote:
This morning my parental controls are gone. Rebooted, nothing. Tried to enable parental controls, cloud error. Uninstalled app, reinstalled, now my subscriptions do not show up and the parental control list is completely gone. Getting lots of 'cloud errors'.
Mar 31, 2023Guru - Experienced User
- WendyJune73Mar 31, 2023Initiate
Yes! I had to uninstall the app and reinstall and its all back! Thank you so much! I have teenagers and can not live without the parental controls!!
- FURRYe38Mar 31, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
