druvar7
Mar 07, 2022Aspirant
Parental controls timezone mismatch
Timezone of browsing history in Parental control inside Orbi App doesnt match with local timezone. Since Parental control feature is completely managed by Netgear/Orbi, leaving me no place to fix the timezone.
Can someone help?
What devices do you have Orbi app installed on?
What time zone are you using on the RBR?
How far off is the mismatch seen in the Orbi app vs RBR?
Is DST enabled on the RBR?
- druvar7Aspirant
What devices do you have Orbi app installed on? Android Phone - Oneplus 6T
What time zone are you using on the RBR? - GMT +12:00(Auckland)
How far off is the mismatch seen in the Orbi app vs RBR?- Around 13 hours behind by current time
Is DST enabled on the RBR? - Yes Daylight saving is enabled
