dolimite
Nov 02, 2021Aspirant
parental controls
I have an orbit router rbk752. the parental controls no longer work on my childrens macs. I block their computer and they are still able to get online. any ideas?
alphanstein
Nov 08, 2021Guide
Macs use dynamic MAC addresses, you would have to change the setting on them to use a fixed MAC address, this would allow the Orbi to then block them everytime.
- CrimpOnNov 08, 2021Guru - Experienced User
In addition to iPhones, this is now the default for new Android phones and tablets as well. That option in settings works as long as the kids are not able to access the settings menu and change it back to 'random'.
- dolimiteDec 06, 2021Aspirant
her mac address has not changed and the ip is still the same. I still cannot block her computer on my orbi. any other ideas?
- claudiutDec 19, 2021Apprentice
Hey dolimite
Are you able to see the devices in the iOS app?
Since my system auto-upgraded firmware to v 4.6.5.14 I'm getting a CDIL-API-FAIL error when trying to access device list or trying to add a device to a profile in smart parent controls.
dolimite wrote:her mac address has not changed and the ip is still the same. I still cannot block her computer on my orbi. any other ideas?
- smithj33Dec 23, 2021AspirantDid you ensure the dynamic was turned off? Once you do that, you have to restart the phone or tablet. That's what I had to do to get parental controls working again after the iPhone update.
