Chairmaker
Feb 28, 2023Aspirant
product advice - no reset button needed, parental control
Hi Guys I hope you can help, I am new to this. I am looking for a suggested router I can purchase but it needs to be properly kids proof. I am struggling find one. I have spent a few hours looking ov...
Feb 28, 2023Guru - Experienced User
So one simple solution would be to put the wifi router in a locked room with no access and only with someone with the key. If the master bed room doesn't have a lock, put on on and put the router in here.
Most all business and home class routers have a reset button for in case of someone forgets all the user configurations and configured router and wifi passwords, the system can be reset and re-setup. Also used as a troubleshooting step where needed. This is industry wide.
Most all home class routers have some form of remote control configuration, though some are limited to mobile apps that don't have advanced configurations as seen on the routers web page, so keep this in mind. NG has removed the web based remote web page control for security reasons so you might find other router mfrs that may support this...
Mobile apps for routers can have parental controls and security controls as well. NG has some that are subscription based. There has to be someone with email and cell phone code access to get access to the mobile app controls here so if the child doesn't have this, then this could be of some help.
One could also do more parenting and discipline any offending events with the child as well. I.e. removing internet devices as a disciplinary action.
Chairmaker
Mar 01, 2023Aspirant
Thank you for your quick response. I have just read it due to the time difference. This is helpful. Just one final question if you would be so kind. You mentioned that NG does not allow remote web access. Does this mean that if I used the 'app' it would do the same thing remotely but just via a cell phone? So I could switch off or pause the router from a different location?
Thanks
