NickPapagiorgio
Mar 09, 2023Tutor
RAX45 Smart Parental Controls - Activation fails after FW upgrade
I agree!! I am having the same exact issue with my Nighthawk RAX45. I bought a one year subscription almost 2 years ago, SAME issue! (error code: SPC-ACT-FAIL) I went through hell talking to SEVERAL ...
breakc0de
Mar 09, 2023Tutor
I have the same problem with my ORBI RB750 - I have been locked out of SPC for 4 months now. I have been working with level 2 support since December with no luck. This bug is ridiculous. We need to somehow get some major visibility to this issue so Netgear will actually do something about this.
- NickPapagiorgioMay 19, 2023Tutor
Hi Furry, will NG respond back to this thread at some point, or will they potentially post a solution somewhere else that I have to go look for?
Thanks
- KaballasMay 31, 2023Initiate
Also same issue. I have RAX70 and after last FW upgrade SPC worked for a bit and then just stopped. Didn;t track anything. Then I made the mistake of resetting the router and all went down the drain from there. Through I'd let subscription expire , was due in 1 month, then created new subscription and still the same. Have reset the modem probably 10 times, loaded old firmware which worked and still the same. Paying a premium for these products just for it to fail is just poor.
