nkd
Dec 08, 2021Apprentice
RBKE963 no parental controls in orbi app
So I upgraded from rbk800 series to this since it’s slapped on the box it has smart parental controls from best buy. Please don’t tell me netgear is just f false advertising this thing and it’s not ready. There is no parental control tile in orbi app.
Parental controls are installed and handled thru Orbi app. There is a tile that should appear there.
Have you tried looking at the Add-Ons menu in the Orbi app to see if Smart Parental Controls are seen?
https://www.netgear.com/home/services/smart-parental-controls/
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-ControlsYou may need to have NG support help you get it set up is all.
No false ads. It works.
- Blanca_ONETGEAR Employee Retired
Hi nkd
Welcome to NETGEAR Community!
RBKE963 supports NETGEAR Smart Parantal Control.
If you cannot find the NETGEAR Smart Parental Control tile in the Orbi App, please make sure that the following conditions are met:
- You are in a country where SPC is available. What countries is NETGEAR Smart Parental Controls available in?
- Your NETGEAR single sign-on (SSO) account is registered to a country where SPC is available in your MyNETGEAR account profile settings.
- The NETGEAR SSO account that you use to log in to the Orbi app is the same account that your router is registered to.
- Your router isn’t in AP (access point) mode.
Blanca
Community Team- sabeensAspirant
i meet all the criteria to have smart control on this device yet it doesnt show for me either. i live in Arizona and the device is in router mode yet neither the orbi app nor the web interface shows parental controls.
Please reach out to a forum moderator for help and information:
