Mandiliv
Jan 02, 2022Follower
RBR 750 Smart Parental Controls not working (bedtime)
I have had my Orbi system for about a month. With kids on holiday break, I kept noticing my Smart Parental Controls are not functioning entirely. Profiles are set. Devices are assigned. I get history ...
mywifi101
Jan 06, 2022Guide
Mandiliv wrote:
I have had my Orbi system for about a month. With kids on holiday break, I kept noticing my Smart Parental Controls are not functioning entirely. Profiles are set. Devices are assigned. I get history info and see usage times. BUT, the bedtime is not functioning. The internet is not pausing for the devices in the profiles.
I’m new to Netgear land. I came from Google Wifi. Please be patient with me as I’m learning this more robust system.
I have been having issues also with parental controls, mine do not funtion at all. I am unable to see any history on any device. I am also unable to pause any device whether it is time based or selecting to pause a device from the app.
For the comment about setting static IPs it does not make a difference in any of the results. It does not work.
Since you should be under 90 day support I would recommend contacting Netgear. I have had mine for almost a year. Hopefully a mod can see this and provide us input.
RBR750
V4.6.5.14_2.0.54
