Mandiliv
Jan 02, 2022Follower
RBR 750 Smart Parental Controls not working (bedtime)
I have had my Orbi system for about a month. With kids on holiday break, I kept noticing my Smart Parental Controls are not functioning entirely. Profiles are set. Devices are assigned. I get history ...
mywifi101
Jan 08, 2022Guide
Mandiliv wrote:
I have had my Orbi system for about a month. With kids on holiday break, I kept noticing my Smart Parental Controls are not functioning entirely. Profiles are set. Devices are assigned. I get history info and see usage times. BUT, the bedtime is not functioning. The internet is not pausing for the devices in the profiles.
I’m new to Netgear land. I came from Google Wifi. Please be patient with me as I’m learning this more robust system.
For those who are encountering this issue:
After I factory reset my device SPC is working correctly again. I am able to pause and see device history.
Note: If you backup your device settings, you will need to restore them prior to activating SPC though the Orbi app. I performed device setup through a web browser and then reconfigure the Orbi app to activate SPC.
Palvyre
Jan 09, 2022Aspirant
Are your bedtimes working? If I manually pause it works, but the bedtimes aren't doing anything.
