nhenson22
May 09, 2024Tutor
RBR50 No access to parental control settings
I have never had to use the parental control settings on my Orbi RBR50 until recently when I decided it might be time to introduce it. I logged into the router admin and navigated to where I enable C...
May 09, 2024Guru - Experienced User
All SPC controls are handled thru the Orbi app:
nhenson22 wrote:
I have never had to use the parental control settings on my Orbi RBR50 until recently when I decided it might be time to introduce it. I logged into the router admin and navigated to where I enable Circle. I was prompted with a message that Circle was no longer something that Netgear sold and prompted to upgrade to smart parental controls. I hit the upgrade button and allowed the router to reboot.
I now have no option in the router admin to actually setup these smart parental controls, as well as the parental controls option disappearing from my Orbi app on Android.
Have tried a couple of the fixes suggested in threads I have found on here with similar issues, but not had any luck. These also seem to be quite old threads.
Any ideas on how I can get access to this setting so that I can set it up?
I have a base router and 3 satellites as I live in a 3 storey house with a big concrete staircase right down the middle. Having to upgrade this setup would be very expensive just to gain access to a feature which I feel should still be supported?
Current FW version on RBR 50 - V2.7.5.4
Orbi app installed on a Pixel 7, latest version installed
Many thanks
nhenson22
May 09, 2024Tutor
I have no option available to me in the Orbi app either for anything parental control related.
When I updated the router to SPC, the Parental Controls tile disappeared from my Orbi app.
There is also no option to add this from the menu.
I am running the latest android app, and have also removed and reinstalled.
Can confirm that I have ruled out all of the below also -
If you cannot find the NETGEAR Smart Parental Control tile in the Orbi App, please make sure that the following conditions are met:
1. You are in a country where SPC is available. What countries is NETGEAR Smart Parental Controls available in?
2. Your NETGEAR single sign-on (SSO) account is registered to a country where SPC is available in your MyNETGEAR account profile settings.
https://kb.netgear.com/000063796/What-countries-is-NETGEAR-Smart-Parental-Controls-available-in?lang...
3. The NETGEAR SSO account that you use to log in to the Orbi app is the same account that your router is registered to.
4. Your router isn’t in AP (access point) mode.
Thanks
- FURRYe38May 09, 2024Guru - Experienced User
Something to contact NG support about then.
- nhenson22May 09, 2024Tutor
Unfortunately NG support is not an option.
They won't let me raise a support case as my complimentary support date has passed.
The only option I get is to search the knowledge base or visit the community for help!- FURRYe38May 09, 2024Guru - Experienced User
One item to check would be the My Subscriptions on the Orbi app.
Might try a full on factory reset and setup from scratch and walk thru the setup routine with the Orbi app and see if this applies the subscription to the system.Other than this, not sure what else, unless maybe NG is not supporting Circle or SPC on the 50 series Orbi system.
FYI, the all ORBI AC series has gone into EoL status so won't see much FW updates unless some major security issue is seen.
