nhenson22
May 09, 2024Tutor
RBR50 No access to parental control settings
I have never had to use the parental control settings on my Orbi RBR50 until recently when I decided it might be time to introduce it. I logged into the router admin and navigated to where I enable C...
nhenson22
May 15, 2024Tutor
KevinLiT
Thanks for the advice, have just completed a completed a painful factory reset, reinstalled the orbi app and finished setting up.
Everything is exactly as it was before. No SPC options in the app, and no mention of it in the router admin either.
What are my other options?
Thanks
nhenson22
May 15, 2024Tutor
KevinLiT
I also rolled back firmware to 2.7.3.22, but still no parental controls options reappearing...
- KevinLiTSep 27, 2024NETGEAR Moderator
Hello Community Members,
Welcome to the NETGEAR Community!
I understand that you are unable to see the SPC tile on your Orbi app. Please ensure that you are using the same email address for my.netgear.com as you are with your Orbi app. Then verify that NETGEAR SPC is enabled on your device to achieve this you will need to use a computer.
Please follow to instructions below to verify your NETGEAR SPC subscription:
To verify that NETGEAR SPC is active on your router please do the following:
- Launch a web browser on a computer that is connected to your Orbi router’s WiFi network.
- Visit www.orbilogin.net.
- Enter the default user name and password.
The default user name is admin. The default password is password. (The BASIC page will be displayed on initial login). - Select ADVANCED > Security > Parental Controls.
- Click UPGRADE TO NETGEAR SPC at the bottom of the page.
- Select OK. (Please wait for your router to reboot.)
After you enable NETGEAR SPC through your web browser, the Parental Controls page no longer displays in your router's web interface. Use the Orbi app to manage parental controls settings and access NETGEAR SPC.
If you do not have an active subscription, please follow the instructions below to purchase one using your Orbi app:
To purchase a NETGEAR SPC subscription:
- Launch the Orbi app.
- Tap the home icon on the top left of your screen.
- Tap ADD ONS.
- Tap Parental Controls.
- Tap Buy Now > See Pricing.
- Choose a subscription plan and tap Get Started.
- Provide the required payment information.
- Tap the confirmation button at the bottom of your screen to confirm your purchase.
NETGEAR SPC is active on your router.
Best,
Kevin
Community Team
