Hathaway9
Oct 11, 2021Tutor
RBR750 - How to manage parental controls subscription
So... I've signed up for a year of parental controls but can't seem to find where I manage the subscription on the netgear site. Can anyone point me in the right direction? Thanks
- Oct 11, 2021
Click on "add ons"
Hathaway9
Oct 11, 2021Tutor
I don't have an option on the app for subscriptions. I assume you're referring to the Orbi app that I use to maintain my router and everything. Account management, support and profile options from the home menu don't show anything useful either. I want to change my setting to not auto-renew but it doesn't seem to show me how to control that.
Hathaway9
Oct 11, 2021Tutor
see attached screenshot for my home menu options
- fargozhuOct 31, 2021TutorI don’t have the add-ons option and my router is running the latest firmware 4.6.5.14
Any thoughts?- plemansOct 31, 2021Guru - Experienced User
Are you subscribed to parental controls and is it running?
Then it should give you an option. In mine, if my parental controls/other add in's aren't running, it doesn't show the option.
If that doesn't help, please start your own thread so we're not confusing your details with the OP's
