iqi
Oct 28, 2021Aspirant
RBR850 - Disable Internet Access but enable local intranet access
I just bought the RBR850 and am struggling to find in the user manual the instructions on how to disable Internet access for a device on my network but allow local network devices to connect to it. ...
Oct 29, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
For Smart Parental controls, Please visit the following Forum:
https://www.netgear.com/home/services/smart-parental-controls/
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Thank you
