Batch48
Sep 28, 2021Aspirant
RBR850 - SPC trial MISTAKENLY activated - Cannot set custom DNS servers?
Hardware reference: One Orbi RBR850 + two synced Orbi RBS850 satellites running Netgear firmware version 4.6.3.16_2.0.51. Windows 10 PC using Firefox v92.0.1 and Chrome v94.0.4606.61 browsers to acce...
Sep 29, 2021Guru - Experienced User
Factory reset the RBR and setup from scratch using a wired PC and web browser. Avoid enabled any Armor notifications on the RBRs web page. Don't enable or select the SPC icon on the Orbi app.
You should be able to set DNS addresses after you set up the RBR.
Batch48
Sep 29, 2021Aspirant
Yes. Performed this EXACT procedure TWICE. Still unable to set DNS server addresses.
When I delete and reinstall the Orbi app after the factory reset and RBR setup via Ethernet connected PC and web utility the SPC shows ACTIVATED - OFF in the Orbi app tiles.
Thus SPC must be registered to the account and the registers device?
Sent another request to Support today asking again to delete SPC from the registered account and the registered RBR850. Still waiting a reply.
- FURRYe38Oct 01, 2021Guru - Experienced User
Try a reset with the RBR disconnected from the ISP modem/ONT. Walk thru the setup wizard and select manually setup. When you get to the home screen, Don't show again for the Armor window. Go in and see if DNS can be set to Custom...
- Batch48Oct 01, 2021AspirantThanks for the help. I’ll try to setup the RBR850 while disconnected from the ISP. I will report the result.
- CrimpOnOct 01, 2021Guru - Experienced User
Batch48 wrote:
Sent another request to Support today asking again to delete SPC from the registered account and the registered RBR850. Still waiting a reply.How are you sending requests to "Support"?
My "90 days" expired years ago, and I have yet to find a method to reach Netgear support directly. Are you within your "90 days"?
Or... sending messages in regard to the SPC subscription?
The original 90-day support coverage for my Orbi RBR850 is expired. I'm sending messages to Support re the SPC activation. They reply to the SPC support requests with little help and then immediately close the case so no further comms or action can be taken. If another RBR850 factory reset and reconfig while disconnected from the ISP doesn't solve the issue I may be forced to subscribe to a 6 months support plan on the devoice in order to resolve this issue. I'm convinced there is a bug in the SPC registration info at the server.
- ChristineTOct 05, 2021NETGEAR Employee Retired
Hello Batch48 ,
We are continuing to investigate this issue. Can you please send me a private message with the serial number of your device. I am working with the engineering team to see if this issue can be fixed on the back end while we continue to debug this internally.
I sincerely appreciate your patience and understanding.
Best,
ChristineT
