daledx00
May 21, 2022Aspirant
RBR850 DNS problem
So Parental Controls turned itself on in my Orbi app on my 'phone - Netgear seems to have opted me into a trial without my consent. As a result, my Orbi RBR850 router has now selected Comcast's DNS s...
May 21, 2022Guru - Experienced User
Did you try to power OFF the router for 30 seconds then back ON after disabling SPC in the Orbi app?
Might need to factory reset the RBR and setup from scratch using a wired PC and web browser. Don't setup using Orbi app.
daledx00
May 23, 2022Aspirant
I turned off Parental Controls in the app then used the web app to install a back-up of my router settings (in which I had used the public DNS). This worked but the issues remain - why Parental Controls self-activated in the Orbi app and why the DNS Address selection in the web app was greyed out (still is, by the way). If this happens again (where the web app changes my DNS settings to my ISP instead of my preferred public DNS provider and greys out my ability to change back) then I will again install the back-up for the router.
- FURRYe38May 25, 2022Guru - Experienced User
I would factory reset and setup from scratch using a wired PC and web browser. Don't install from a back up. The backup may have the problem included. Once the RBR is setup from scratch fully, with out any SPC enabled and you set custom DNS that you set. Then save off a new backup config to file at this point. Might avoid using Orbi app as well.
