jeffreyrinek
Dec 20, 2021Star
RBR850 Requires Factory Reset after Power Outage
Hello, Happy Holidays and New Year to All! I have an Orbi RBR850. After a power outage that extends beyond battery backpack, the Orbi losses all settings. I have to do a factory reset and reprogram ...
Dec 21, 2021Guru - Experienced User
Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed or loss of configuration.
You might try this:
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
