Flbrit
Nov 10, 2023Tutor
RBRE960 ORBI App Parental Controls
I accidentally turned on Parental Controls free trial via the ORBI App (because I accidentally hit the annoying pop up), and now I can't use the Advanced > Security > Access Control via the web inter...
CrimpOn
Nov 10, 2023Guru - Experienced User
Does the app show Connected Devices and the goal is to get rid of the annoying message?
Or, does the app not show Connected Devices?
- FlbritNov 12, 2023TutorThe App does not show me connected devices, on the home page it says 5 devices connected for example but then when you click on it it just takes me to SPC setup
- CrimpOnNov 12, 2023Guru - Experienced User
One accidental click and you are now in purgatory!
Does the Orbi web interface at least show Attached Devices (as it should?)
Might start with opening a case with the subscription service:
https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service
- FlbritNov 15, 2023TutorYeah, one click and I’m doomed 🙂
Web interface for now shows the devices but if I carry on and setup up the SPC then I can’t see them in the web interface, it just tells me to use the app.
Thanks for the link I will try it
