Flbrit
Nov 10, 2023Tutor
RBRE960 ORBI App Parental Controls
I accidentally turned on Parental Controls free trial via the ORBI App (because I accidentally hit the annoying pop up), and now I can't use the Advanced > Security > Access Control via the web inter...
CrimpOn
Nov 10, 2023Guru - Experienced User
Does the app show Connected Devices and the goal is to get rid of the annoying message?
Or, does the app not show Connected Devices?
Flbrit
Nov 12, 2023Tutor
The App does not show me connected devices, on the home page it says 5 devices connected for example but then when you click on it it just takes me to SPC setup
- CrimpOnNov 12, 2023Guru - Experienced User
One accidental click and you are now in purgatory!
Does the Orbi web interface at least show Attached Devices (as it should?)
Might start with opening a case with the subscription service:
https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service
- FlbritNov 15, 2023TutorYeah, one click and I’m doomed 🙂
Web interface for now shows the devices but if I carry on and setup up the SPC then I can’t see them in the web interface, it just tells me to use the app.
Thanks for the link I will try it
