Stege
Sep 11, 2022Tutor
Cant unlock premium SPC future on RBR50
Hallo I can´t unlock the premium future of SPC (Mytime) on my RBR50 router My trial worked perfect but the trial period is closed and when i tap the unlock premium ind the android app there ...
Stege
Nov 01, 2022Tutor
When i try to reactivate its say that no plan i is available
Stege
Nov 01, 2022Tutor
The trial was ok but after expire it cant be activated again
- JwouterNov 01, 2022Aspirant
I have a plan available, however i can’t pay there is a green tick box to accept terms and conditions that I can’t seem to select...... logged a call 2 weeks ago but nothing from netgear.
- StegeNov 01, 2022TutorThey must get it fixed asap
- FURRYe38Nov 01, 2022Guru - Experienced User
If you have continued problems, contact NG support for additional help and information.
As said call is open with Netgear , called them multiple times.
so no Netgear has niet been very helpful
hi,
version 2.20.1.12
j wouter
- StegeNov 01, 2022Tutor2.7.4.24
- Sulphate9402Nov 05, 2022Guide
Im having the same effin problem with my RBR850. Its not an issue with the firmware or router. Its a dang issue with the app software. The monkeys that coded it made the TOS checkbox/circle un tickable.
And since we cant accept the TOS, we cant click the purchase button. FIX THIS ASAP. How did this bug make it to production?
I've tried this on IOS And ANDROID and the same issue persists.
- JwouterNov 06, 2022Aspirant
Don’t think it’s the app , my money it’s that the issue is with our accounts ….
- StegeNov 06, 2022TutorSomething is wrong an a solution is needed ASAP 😡
- Sulphate9402Jan 02, 2023Guide
Can someone at Netgear seriously take a look into this? Its been 2 months since my SPC expired and I can't purchase the subscription because of this issue.
- KevinLiTJan 02, 2023NETGEAR Moderator
Hello Sulphate9402 ,
Welcome to the NETGEAR Community!
I understand that you are having difficulties with purchasing an SPC premium subscription.
Please follow the steps below to subscribe to SPC Premium:
To start a subscription for SPC Premium:
1. Launch the Orbi or Nighthawk app.
2. Tap the Parental Controls tile.
The SPC dashboard displays.3. Tap the "Your trial is expiring" banner at the top of your screen.
4. Tap See Pricing.
5. Choose a subscription plan.
6. Tap Get Started.
7. Fill in the required payment information.
8. Tap Place Your Order.
Please navigate to the link below to see the available SPC Premium plans:
(If you are seeing any errors during this process please let us know)
Best,
Kevin
Community Team
Thanks for your response!
What error are you seeing when you attempt to subscribe to SPC Premium?
Best,
Kevin
Community Team
The Terms & Service checkbox/circle is not tickable/tappable/touchable in the Orbi app. Issue is on both IOS and Android.
Since TOS cannot be agreed to, we cannot complete the purchase to buy SPC. Issue happens when trying to purchase Netgear Armor and Pro Support. Trying to purchase anything through the Orbi app does not work due to this issue.
