HaniRBR750
May 19, 2024Aspirant
Re: Impossible to enable / buy parental controls on RBK852
I also have the same issue. I tried changing the country and reset the mesh system but the problem persists. Still cannot buy the SPC after the trial has expired. Please advise the solution for t...
May 20, 2024Guru - Experienced User
What region are you located?
What model Orbi system do you have?
Try a factory reset on the Orbi system and setup from scratch using Orbi app?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
- HaniRBR750May 21, 2024AspirantAll the above have been checked and done. I can see other complaints on the same matter from other people.
- HaniRBR750May 21, 2024AspirantI have the same issue. Cannot buy the premium SPC after the trial. It says plan is not available
- FURRYe38May 22, 2024Guru - Experienced User
Something to contact NG support about then:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".Good Luck
