SM09
Jun 06, 2024Tutor
Re: Netgear Smart Parental Control Premium Subscription - RBK50
I have the exact same issue, the app states there are no pricing options for parental controls for Australia. However if I change my location to the US then I have the pricing option to subscribe. I ...
SM09
Jun 10, 2024Tutor
None of these links answer the question. The option to purchase smart parental controls is not available if the location is not set in the US. Netgear needs to fix this issues as the routers are packaged in Australia with Smart Parental Controls.
Jun 27, 2024Guru - Experienced User
Something to make contact with NG support about. That's all beyond forum help.
Good Luck.
