Juliocsl
Jan 04, 2025Aspirant
Re: Orbi RBR850 missing parental control tjle
I am facing the same issue. No option as the screenshots above. Same on app. No options of add on in home. Any suggestions?
Juliocsl
Jan 06, 2025Aspirant
The problem is that that option is not showing.
Unfortunatelly something is not configured correctly and the option is not even visible.
If you see above they have posed some images, showing the menu without the prental control visible.
Thank you.
Jan 06, 2025Guru - Experienced User
Please submit a bug report thru Orbi app:
