brandoncampbell
May 01, 2024Star
Re: Overnight device activity consuming allowed time
Same issue. I noticed there is an option to put sites in Site Manager and set to unlimited. Unfortunately, if they are IP addresses you cannot. I have an Apple IP address (17.57.144.39) that keeps pi...
brandoncampbell
May 20, 2024Star
Whats the point if the Parental Controls if I have to manually disconnect from WiFi or put in Airplane mode? Also, why would I need to contact Apple? This is obviously a problem with Parental Controls. The only possible fix, if netgear updated the software to allow IP addresses to the allow list. This would then allow me to add this IP to the unlimited section therefore resolving the constant communication consuming the bandwidth. Does anyone know if Netgear monitors this? I no longer have a warranty on my orbi system and would love to get this feedback to them.
May 20, 2024Guru - Experienced User
Something to contact NG support then and let them know:
