brandoncampbell
May 01, 2024Star
Re: Overnight device activity consuming allowed time
Same issue. I noticed there is an option to put sites in Site Manager and set to unlimited. Unfortunately, if they are IP addresses you cannot. I have an Apple IP address (17.57.144.39) that keeps pi...
brandoncampbell
Mar 30, 2026Star
Never did hear back from them on if this was fix. It appears the long-standing issue with Smart Parental Controls remains unresolved. Two years after canceling for this exact reason, I was enticed back by a discount, only to find the same flaw: background activity is being counted as active "Time Limit" usage. For example, I set a 1-hour daily limit for my daughter’s devices. Even when the devices are asleep or she is away at school, background processes (updates, "phoning home") exhaust the entire time limit within an hour. I regret paying for a service that is currently unusable. Is there a fix for this, or can I request a refund?
Mar 31, 2026Guru - Experienced User
brandoncampbell wrote:Never did hear back from them on if this was fix. It appears the long-standing issue with Smart Parental Controls remains unresolved. Two years after canceling for this exact reason, I was enticed back by a discount, only to find the same flaw: background activity is being counted as active "Time Limit" usage.
Hard to see how Netgear could sort out background activity from other usage.
Have you looked into the screen time management controls in the devices? Not sure on Android, but iOS does have controls to schedule downtime and also manage communications during downtimes. You could use these as well as the parental controls.
