dd-walker
Feb 07, 2022Tutor
Parental Control stopped working
I have Parent Control subscription for about a month. It's been working fine. But today it stopped working. It doesn't show usage History and doesn't limit the usage. The firmware version is 2.7....
- Nov 08, 2022
(For some reason all the other related topics have been marked as closed)
Netgear Support finally resolved the issue I had with SPC not working following the force migration in January 2022. Basically, it would work for a few hours and then stop applying rules, logging history, etc. It was resolved end of October.
The problem was caused by Circle settings not allowing Netgear SPC to work. Level 3 support recreated by setup in their lab and built a script that deleted all trace of Circle.
After running this script into the router, I did factory reset and reinstalled the app. The profiles weren’t lost and SPC has been working for 2 weeks non stop now.
So if you are a previous Circle user on Orbi and could never make SPC work, they have a solution. Just need to point them to Level 3 script they have built. (PM me for my case number)
Thank you to Bernard for Level 2 who finally got this resolved.
Feb 15, 2022Guru - Experienced User
If you have a case open with NG support then keep in contact with them until the problem is resolves as theres nothing else we can help you with here in the forums.
Good Luck.
Chuckg1 wrote:
3 times in one month I had to do the factory reset, install config, reinstall app, rebuild profile. It only bought me 2-3 days of working SPC before it fails again and stops tracking usage or applying filters. I stopped wasting my time and ask Netgear to find a fix ASAP. Case is still open. Circle worked more than a year with zero interruption. SPC from Netgear is broken.
Chipchan
Jul 25, 2022Aspirant
I have had success turning parental control off and then back on at the settings page.
The cloud icon on upper left corner takes you to a menu:
Settings>Parental Control>enable Smart Parental Control: off then wait a while and then on again.
Hope this helps.
- Chuckg1Nov 08, 2022Star
- FURRYe38Nov 08, 2022Guru - Experienced User
Thanks for letting us know the details and glad there seems to be a solution.
- BelomniDec 07, 2022AspirantAn you give me your case number for parental control post circle customer fix?
- maninarenaJan 07, 2023Aspirant
I can't get netgear, orbi or armour to stop anything through parental controls or otherwise, can you share your solution with me?
thanks,
Pat
Maninarena@yahoo.com
- miniz98Jan 08, 2023AspirantCan you send me the script? Mine has been so problematic.
- miniz98Jan 18, 2023Aspirant
Please message me your case number they cannot fix my issue i have a stuck profile that cannot be deleted.
- SamchakrFeb 05, 2023AspirantHi,
I have been facing the same issue and Netgear support has been sitting on this issue since Dec 19th! Could you please share your case number which helped resolve the issue. Much appreciated and thank you! - miniz98Feb 05, 2023AspirantMy case finally was moved to a engineer high level support. I will let you know when they fix it.
