jelabarre59's avatar
Apr 25, 2021
Restoring LOCAL parental control functionality
So since Netgear is removing the "Live Parental Control" from their routers (which is good, I don't want to have to go to some other site just to change configuration), just WHEN are you going to restore the LOCAL Parental Control functionality in the firmware?  Properly, it should be available *NOW* (as it never should have been removed in the first place) so you should be providing a patch to fix your oversight immediately.  I need a function that DISABLES connections immediately, which means I would have to have local controls.  An online filter only works for manipulating DNS lookups (and probably is broken by DNS-over-HTTPS, and I can't shut that off on a school-managed Chromebook anyway).
  • CrimpOn's avatar
    CrimpOn
    I am not certain that Netgear is removing Parental Controls.  Disney Circle is still working. And, the "New" Netgear version of Parental Controls is available on the original Orbi product line and will be available on the AX product line "in a few months."
    https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Parental-Controls-missing-on-RBR850/m-p/2088137#M4573
    I believe what is happening is that the older "Live" Parental Controls is going away in favor of the newer products.
    My understanding is that Netgear got into the Parental Controls business (with "Live", with Disney, and now by themselves) because the methods that had been used on routers for years no longer met peoples' needs.  The new "Smart Parental Controls" come in free and subscription versions. (See toward the bottom of the page for differences)
    https://www.netgear.com/home/services/smart-parental-controls/#parental-control
    The Orbi "app" will disable connections immediately, although that is probably not the intention.
    It is really frustrating that Netgear does not have employees watching the community forums, where customers discuss Netgear products amongst themselves.  We are left to speculate about things and have no influence on Netgear business decisions.
    • nalawa63's avatar
      nalawa63
      Tutor
      Just bought a D7800 and Netgear have definitely removed "live parent controls" and replaced it with absolutely nothing!  It provides absolutely no way to restrict/control/manage my children's internet access, a must in modern society!  Netgear's new "smart parental controls" aren't available on the nighthawk so looks like I'll be returning it and looking for an alternative :-(
  • What is the go with no parental controls within the D7800 to allow me to restrict/monitor my children's internet access? Surely this is a mandatory requirement for a modern family.  Unless I can get some level of control I will have to return this and find a different modem/router which supports my requirements.
