seafur
Sep 04, 2021Initiate
Smart Parent Controls in Nighthawk / MR60 - tile missing
I have the MR60 / MS60 firmware V1.0.6.116_2.0.54 Trying to get Netgear Smart Parental Controls going, I've read the old posts stating that parental controls were not yet available on the MR60. H...
JVP73
Sep 27, 2021Aspirant
Just come home with the MR60. Clearly misled by the sales rep that this would include parental control options but as I am discovering, it doesn't. Do you still have this set up and if so, have you found an alternative?
- CrimpOnSep 27, 2021Guru - Experienced User
Hope this was purchased from a place with a good return policy. Neither Circle nor Smart Parental Controls (SPC) work on the MR60. That web link suggests that SPC is available on the MR80, which is also false. (Check the product data sheet)
- seafurSep 28, 2021Initiate
No solution, the MR60 apparently has been left in the dust regarding parental controls. It was in between Netgear's use of Circle and SPC. Funny thing is after realizing how much cheaper the MR60 was than the Orbi and how well the MR60 was performing I called Netgear during my 90 day support, while I still had the box from Costco, and asked "what's the difference between MR60 and Orbi". The answer was Orbi is for a bigger house with more metal. I chuckled and said: yep, that's non-sense. Sure enough 6 months later I find out on my own what the difference is.
- MichEEOct 30, 2021Aspirant
Thanks for this info. I am returning mine tomorrow!
