dotcomdumdum
Jun 15, 2024Follower
Smart Parent Controls stopped working after trial expires then signing up
Apparently if your SPC trial expires and you pay for a 1 year subscription netgear isn't smart enough to lift the software restrictions. Customer service chat was unable to provide any solutions. C...
Jun 27, 2024Guru - Experienced User
Try a factory reset on the NH router and setup from scratch using a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Then connect the NH app and see if SPC works...
