maneesh
Nov 04, 2024Aspirant
Smart Parental control - Country Support
I just brought a REX 300 Nighthawk thinking Smart parental control app will be available to control my kids screen time. Now. the support says the app doesnt support Smart parental control in your country. Is there any way to bypass the country details to enable the parental control app.
I have been using Circle 1st gen with my Nighthawk R7000 and never had issue with it in the country.
Any help will be greatly appreciated as i would need to return this and go for a Synology or Asus one
1 Reply
Check to be sure SPC is supported on the model NG router you have:
And officially supported in the country your located in:
Circle differs from SPC. Circle is no longer supported I believe by NG.
