JRGnOC
Jul 17, 2022Aspirant
Smart Parental Control, but getting the following error, SPC-ACT-FAIL
I am having the same issue, where I paid for the premium subscription, Smart Parental Control, but getting the following error, SPC-ACT-FAIL.
My Orbi RBR750 firmware is V4.6.8.2_2.1.9
Jul 18, 2022Guru - Experienced User
JRGnOC
Jul 18, 2022Aspirant
Thank you for the links. I have gone through all of those already, but still get the error, SPC-ACT-FAIL when trying to setup the Parental Control from the Orbi phone app.
Do you have any other suggestions?
- FURRYe38Jul 19, 2022Guru - Experienced User
Might updated to v.5 on your system:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
Or file a bug report with in the Orbi app:
- JaydeeJDAug 23, 2022Aspirant
I am having this same issue and have tried all the same things. No luck! ISSUE IS NOT SOLVED!!
- JRGnOCAug 23, 2022Aspirant
Hi.
I was able to resolve the issue with Netgear Tech Support.
We did two things.
1. Update Router and Satellites to latest firmware, 4.6.8.5
2. Reset the Router to factory settings.
After doing both of these, I was able to setup Parental Controls.
When you perform a factory reset, does it "downgrade" the firmware?
Had you completed a trial prior to having the issue?
Thanks.
