JRGnOC
Jul 17, 2022Aspirant
Smart Parental Control, but getting the following error, SPC-ACT-FAIL
I am having the same issue, where I paid for the premium subscription, Smart Parental Control, but getting the following error, SPC-ACT-FAIL.
My Orbi RBR750 firmware is V4.6.8.2_2.1.9
JaydeeJD
Aug 23, 2022Aspirant
I am having this same issue and have tried all the same things. No luck! ISSUE IS NOT SOLVED!!
JRGnOC
Hi.
I was able to resolve the issue with Netgear Tech Support.
We did two things.
1. Update Router and Satellites to latest firmware, 4.6.8.5
2. Reset the Router to factory settings.
After doing both of these, I was able to setup Parental Controls.
- JaydeeJDAug 23, 2022Aspirant
When you perform a factory reset, does it "downgrade" the firmware?
Had you completed a trial prior to having the issue?
Thanks.
- Chuckg1Sep 07, 2022Star
Factory reset only works for a few hours/days/weeks and it will fail again. The permanent fix to make SPC works has never been released. Almost a year of waiting now (RIP Circle which worked so well)
