Shriekrvce
Feb 23, 2022Initiate
Smart Parental Controls - premium plan reactivate -i was trying the trial version and it locked late
Hello Team, I recently installed RBR 750 Router with two satellite system, everything was fine, earlier it was a drop, never I faced issues. I activated the free trial of parental version and la...
- Feb 28, 2022
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What Orbi App version and mobile platform are you using with the Orbi app?
Feb 28, 2022Guru - Experienced User
- ShriekrvceMar 03, 2022Initiate
Thank you buddy. YEs I did that long back factory reset and did all again and ignored those parental part. Its crazy at least the app should show a reminder its expiring do you want to continue or not and then entangle, but it does not or maybe I missed it. appreciate your answer.
have a good day
Thank you,
Sreekanth
- FURRYe38Mar 04, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- AintanantMar 15, 2022Guide
This has not worked. It is not a solution. It is a Hail Mary. Also reaching out to moderators is pointless, I am waiting for a private message since October.
- FURRYe38Mar 15, 2022Guru - Experienced User
- Chuckg1Mar 15, 2022StarFurry are you a Bot? It is the second thread I see an empty reply from you with just a link to a FAQ that does not address the question.
Factory reset does not permanently fix the problem. It reoccurs shortly after.
