wndbj8nw
Jan 10, 2024Aspirant
Smart parental controls - "This plan is not available"
Hello,
I have the Orbi RBR50v2 using firmware V2.7.4.24. I was previously using Circle to manage parental controls but after being suggested to upgrade to Smart Parental Controls from the web interface, I did just that. I used the free trial and during which everything worked just fine.
However, the trial expired with no notifications and since I am unable to subscribe to continue using the service. When I try I am greeted with the "This plan is not available" message.
I have performed a factory settings reset through the web interface at Advanced >
Administration > Backup Settings > Revert to factory default settings. This made no difference. But one thing that I think should be noted is that after I reinstalled the Orbi app on my phone, the profiles of my children were still there. So it doesn't appear that all the settings were removed.
Please provide me some information that will allow me to subscribe to the Smart Parental Controls.
Thank you.
1 Reply
I'd try first to update the RBS then RBR lastly:
Then factory reset using:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
Then setup from scratch using a PC and web browser first, don't use Orbi app:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerOnce the system is setup, then log into the Orbi app and see if you can check your subscription using the 3 horizonal lines top left corner of the app to show menu list and see if Subscriptions is listed there and check status or see if it directs you to the SPC subscription or any Circle subscriptions?
You may need to contact NG support for help and information regarding subscriptions as this is beyond forum help:
