ReZeR
Apr 09, 2023Guide
Smart Parental Controls has stopped working (again?)
Hi, Today, SPC has stopped working. Within in the Orbi app I cannot see any devices listed, profiles cannot be added or editied, and I cannot disable (with the intention to re-enable) SPC; with the...
mkhs
Apr 23, 2023Aspirant
I did a factory reset on the orbi and everything is working now. Lost all the profile information for devices, but after resetting those parent controls are working again, showing usage etc.. Hoping that doesn't happen again.
Apr 24, 2023Guru - Experienced User
What Orbi model do you have?
What FW is loaded on the Orbi system?
- mkhsApr 24, 2023AspirantI’m not extremely tech savvy but I think the router is RBR50v2
FW V2.7.4.24
I have two satellites also.
